Abgeschickt von Bernd Bauer am 20 Mai, 2006 um 12:51:02
Antwort auf: Replacement coil for '93 GS ?? von Laurent am 20 Mai, 2006 um 10:15:35:
Hi Laurent,
: Anybody knows a good replacement for this coil ?. I am looking for a straight fit so I don't have to cut the frame or bracket. I have read that K100 and R1100 coils would fit.
the R1100 coils can be used, but you have to make your own bracket. Furthermore the connectors for the primary and secondary side of the coil are different.
It is not a big deal because the needed connectors are available at you BMW dealer.
And to make a bracket is pretty much straight forward too.
Here I have described the usage of the "oilhead" coil:
http://www.r100.net/modules.php?name=News&file=article&sid=30
http://www.r100.net/modules.php?name=News&file=article&sid=40
The sites are written in german but at least you can take a look at the pics.
If buying directly from Germany is an option for you then I recommend that you get in contact with Q-Tech, because he offers a oilhead coil plug&play kit.
http://www.q-tech.de/01WEBDOZUEANLAGEN.htm
Gruesse aus Koeln
Bernd Bauer
89-93 R100GS/PD
http://www.R100.NET
