Abgeschickt von hansen am 20 Mai, 2006 um 10:57:21:
Antwort auf: Replacement coil for '93 GS ?? von Laurent am 20 Mai, 2006 um 10:15:35:
Hi Laurent,
afaik the only straight fit replacement is the stock coil. On a K100 coil you will have to modify the bracket, a R1100/1150 coil will require a modification of the bracket and the connectors.
I can't tell anything about the Silent Hektik stuff except that a friend of mine tried their double ignition coils a couple of years ago. He got disappointed and refitted the Andrews coils he used before.
Regards
