Abgeschickt von Matz Rosenquist am 07 Maerz, 2002 um 10:09:51
Antwort auf: Magura Kurzhubgasgriff von Joachim R. am 06 Maerz, 2002 um 13:06:07:
Morning Joachim and All!
: da ich gerade bei meiner Kuh einige Veränderungen vornehme, möchte ich auch einen Kurzhubgasgriff anbringen.
I presume you've got a "real" Kuh, a G/S with 32 mm Bings. If so, one very easy and cheap way of getting a "Kurzhubgasgriff" is to replace the present camgear in the handle. Use the one from an R100 RS, or perhaps from any bike with 40 mm Bings. That segment has got a camlobe on it, resulting in a progressive opening of the butterfly and resulting in much shorter throw.
I've done this on my G/S PD when used for enduroracing and it worked very well. Drawback is increased force needed, but still tolerable. Advantage is, you keep all the rest of the switchgear.
Happy turning!
Rdgs
Mr MR
