Re: druckplatte
Abgeschickt von Bernd Bauer am 03 Dezember, 2003 um 17:20:34
Antwort auf: Re: druckplatte von Matz Rosenquist am 03 Dezember, 2003 um 13:14:36:
Hi,
: >Kuplungsexperten, passt die druckplatte von K100 >auch in Boxer und hat die den gleichen effekt >wie die von K75?
: Along with the Q-Tech prepared Basic I bought last year, I got all documents connected. On one invoice from Q-TECH there is a "21 21 1 457 458 druckplatte Kuppl. K" specified. From that I conclude a YES is the correct answer!
but this part number is for the pressure plate of the K75's.
It is also possible to increase the preload of the clutch spring by adding a piece of sheet metal (0,1mm is a good starting point).
BTW will you organise another GS-meeting next year?
Gruesse aus Koblenz
Bernd Bauer
89-93 R100GS/PD ( on the road again )
