Re: Olspritzring und ol im Kardenwelle - R100gs 1992 mit paralever Gabel
Abgeschickt von Peter am 04 Dezember, 2000 um 10:14:59:
Antwort auf: Olspritzring und ol im Kardenwelle - R100gs 1992 mit paralever Gabel von enricone am 02 Dezember, 2000 um 13:38:39:
Hi Enricone,
this triangle shaped hole is only needed for the older models to ventilate the oilfilled swing arm (steel swing arm) into the gearbox.
Many people (mechanics too) do not know that you have to seal the whole after exchanging the oilgard of paralever models.
I had this problem in 1990 too. The mechanic didn't know about the change.
I had to investigate by myself.
The whole in the screw for the mass cable ventilates the gear box.
good luck
