a GS or a G/S ?
Abgeschickt von Christian L. am 20 September, 2005 um 12:54:14:
Antwort auf: R80GS von Marco Torres am 19 September, 2005 um 19:31:09:
Hello Marco.
You write that you are looking for a r80gs.
Is it a model with paralever and 800cc that you are loking for?
They were build from '88 on and replaced the G/S Model (1980 to 1987) with straight swingarm and drive shaft.
Another consideration.
800cc models are considered to lack in torque, a 1000cc model here makes a big difference. This feature is the reason that so many people are retrofitting 1000cc sets (cylinders and pistons) on r80's.
800cc engines are considered to run more smooth, on the other hand, their fuel consumption is higher than 1000cc engines.
As one of the colleagues wrote, motoscout24 is a good opportunity.
May be, if you have found a motorcycle, you might post here on this forum where the bike is located. If there is a member of the forum nearby, he might give you some help when checking the bike.
In the link here under, I give you "the" reference page for G/S and GS.
Best regards,
Christian L.
