Abgeschickt von Joerg am 20 Mai, 2006 um 11:54:26:
Antwort auf: Replacement coil for '93 GS ?? von Laurent am 20 Mai, 2006 um 10:15:35:
Hi,
: Anybody knows a good replacement for this coil ?. I am looking for a straight fit so I don't have to cut the frame or bracket. I have read that K100 and R1100 coils would fit.
Yes, but as hansen explained - you will need to build a bracket.
: I would like to know about the Silent Hektik upgrade....if anyone has fitted it. Just the coil and the whole upgrade.
... don't know the "upgrade", but about 5 years ago I bought the SH coil as a direct replacement (when my grey stock coil failed ;-). It "just works", and had the advantage that it was slightly less expensive to obtain than the stock BMW part :-)
Cheers & greetings from Lausanne,
