Abgeschickt von hansen am 18 April, 2008 um 16:51:59:
Antwort auf: Rims and spokes von BjörnZ am 18 April, 2008 um 14:05:44:
Hej Björn,
the early WP forks should hold the stock G/S front wheel which has an axle shaft diameter of 17 mm.
If your fork does not, could you post a photo? (Upload it to a webspace you can access, and put the direct link in the field "Optionale Bild-URL" of your next posting.)
Hejdå
