Abgeschickt von schraubtrollo am 11 Januar, 2004 um 10:42:06:
Antwort auf: Nabe aussermittig einspeichen von Wilfried am 11 Januar, 2004 um 09:32:59:
lateral deviation on the "retrofitted" bikes I've seen is usually about 5-8 mm.
Ideally you'd want to roughly check it before deciding.
: Hello,
: First of all, sorry for writing in english, but please reply in German..
: I was wondering how far the rear wheel alignment can be (maximum) out of center, to get the right compromise between tire choise and road-holding?
: For example, a HPN sport which uses the disk-brake and R1100 swingarm, is advertised with a (possible) 140 rear tire. Would this be possible with the exact wheel alignment, or is there some "misalignment" to the left ?
: Viele Grüße
: Wilfried
