Re: 1100 swingarm on r 80 frame
Abgeschickt von Marco am 02 Februar, 2002 um 08:17:06:
Antwort auf: Re: 1100 swingarm on r 80 frame von Marco am 30 Januar, 2002 um 15:32:20:
Hello Marco,
that sounds good.
I will wait for your next "prototype" report, concerning this redesign of your swing arm.
Please keep in touch with!
I have build a G/S swing arm (plus 100mm) for my paralever GS 80. I will now assemble this new longer swing and the M1 fork into the GS 80.
I hope the bike will drive correctly.
Further on I will also try to weld my 1100GS swing arm, but I am a liddle frigthened concerning weld process.
Best regards
Hamburg
: Hi Hamburg,
: I'm really going to weld a LARGE plate on the cardan surface. Before doing it of course I'll bring to a friend of mine who is an aluminium specialist to check exactely the composition of the material before proceeding to weld.
: This configuration will allow a smooth travel of the rear arm. Otherwise I should mount the shock in the middle moving battery and maybe filter unit.
: I'll give you detailed information after I'll have done it.
: Ciao
: Marco
